50W white LED headlight driver circuit diagram based on LT3755
Source: InternetPublisher:明天见 Keywords: White LED driver circuit diagram LT3755 WIDTH Updated: 2020/09/05
The LT3755 senses output current on the high-side side of the LED string. High-side current sensing is the most flexible solution for driving LEDs. The PWM input provides a dimming ratio of up to 3000:1, while the CTRL input provides additional analog dimming. Light ability. The LT3755 is available in 16-pin (3mm × 3mm) QFN and MS0P packages. The main technical characteristics of LT3755 are as follows:
(1) Wide input voltage range (4.5~40V).
(2) Output voltage up to 75V.
(3) Fixed current and constant voltage regulation.
(4) 100mV high-end current detection.
(5) Boost, buck, buck-boost, SEPIC or flyback topologies can be used to drive LEDs.
(6) It has programmable under-voltage lockout protection function with LED open circuit and hysteresis.
(7) Open LED status pin.
(8) PWM disconnect switch driver.
(9) The CTRL pin provides analog dimming function.
(10) Low shutdown current: <1uA.
(11) Programmable soft start.
ck="window.open(this.src)" alt="Click to see larger image" />
- Fire safety evacuation emergency signs
- A light fence circuit diagram with LDR
- Infrared detection alarm
- One of the water full alarm circuits
- Gift lamp music box circuit
- Desk lamp dimming soft switch circuit
- AC and DC dual-purpose flash light
- Mains undervoltage and overvoltage protection circuit 2
- Reverse polarity drive circuit
- Night target display circuit diagram
- AN7161N power amplifier circuit diagram
- AC 220V to DC 600V switching power supply circuit diagram
- EW-8W electronic ballast circuit diagram
- Crystal oscillator 80mW FM transmitter production circuit diagram
- Three-phase three-wire active energy meter direct connection type
- Constant voltage current limiting charger circuit
- Positive temperature sensor and coefficient resistor circuit diagram
- Circuit diagram of using NCP3065/NCP3066 to drive LED
- Multi-waveform signal generator circuit diagram
- LT3755 driver LED application circuit
