High energy efficiency, low cost, non-isolated 350mA/12V LED driver
Source: InternetPublisher:无人共我 Keywords: LED driver WIDTH Updated: 2020/07/01
This circuit features an accurate primary-side constant V and constant current controller (CV/CC), eliminating the need for an optocoupler and all secondary-side CV/CC control circuits. It achieves maximum efficiency without the need for a current sense resistor and is the only component used Small, low-cost solution (16 components) with automatic restart for output short-circuit and open-loop protection. Its full-load efficiency is greater than 80% in the entire input voltage range, and its no-load power consumption is <200mW under 265V AC input. It meets EN55015 and CISPR-22B Class EMI standards and Energy Star requirements for solid-state lighting (SSL) products.
ck="window.open(this.src)" alt="Click to see larger image"/>
- Making a photometer with light measuring function
- Measurement and analysis of automatic emergency lighting circuit
- IRS2530D electronic ballast circuit diagram
- DCD-1240 multifunctional rechargeable lighting
- Infrared remote control device circuit
- Use NE555 to make a touch self-extinguishing table lamp
- One of the bead-type emergency light circuits
- Colorimeter circuit
- Gift lamp music box circuit
- Motor speed photoelectric control circuit
- LA4497 power amplifier circuit diagram
- Sensor lighting LED driver circuit
- Principle circuit diagram of three basic working modes of non-isolated switching power supply
- Constant voltage current limiting charger circuit diagram
- Magnetic induction transmitter circuit diagram
- Three-phase three-wire active energy meter direct connection type
- Low frequency amplification feedback circuit diagram
- PLC circuit diagram of CNC machine tool
- Hall sensor signal amplification circuit diagram
- Circuit diagram for driving 4 white LEDs based on charge pump
