Circuit diagram for driving 4 white LEDs based on charge pump
Source: InternetPublisher:newlandmark Keywords: Charge pump circuit diagram white LED WIDTH Updated: 2021/05/30
In this circuit, the white LED driver is an adaptive charge pump based on 1x voltage mode and 1.5x voltage mode . The input of the charge pump is connected to the VIN pin and the output is connected to the VOUT pin. The charge pump has two operating modes: open loop and closed loop. In open-loop mode, the voltage at VOUT is equal to the input voltage multiplied by the gain multiple. When the charge pump operates in closed-loop mode, the voltage at VOUT is adjusted to a constant voltage value (Vreg). An internal current source controls the current to each white LED in a common-anode configuration, and the peak drive current can be programmed through an external resistor (Rset ) .
- Example of LED AC drive circuit
- Fire safety evacuation emergency signs
- IR2153 emergency fluorescent lamp circuit diagram
- Design and production of digital number answering machine
- Solar battery and charging circuit
- Application circuit of CAT3606
- Chandelier brightness controller circuit using thyristor
- Shock resistant soft start constant current LED lighting circuit
- Incandescent lamp dimming circuit using thyristor part 4a
- Mains undervoltage and overvoltage alarm circuit 2
- LA4510 power amplifier circuit diagram
- LA4261 power amplifier circuit diagram
- HA1377 power amplifier circuit diagram
- AN7168 power amplifier circuit diagram
- AN7112 power amplifier circuit diagram
- Blind multimeter circuit diagram
- CDll4CP logic block circuit diagram
- Several typical application circuit diagrams of ND838
- Multi-waveform signal generator circuit diagram
- Square wave clock circuit diagram
