Wide dynamic range gain control amplifier circuit diagram
Source: InternetPublisher:李商隐身 Keywords: Gain control wide dynamic range amplifier circuit diagram Updated: 2021/12/01
The wide dynamic range gain control amplifier circuit is shown in the figure below. Experience has proven that when using FET as a variable resistor to control the gain of the amplifier, when the input signal is 1% of the pinch-off voltage, there will be 1% distortion. If two resistors and a field effect tube are used to form a T-shaped network in the feedback loop, the signal is attenuated by R1 and R2 and then added to the field effect tube, so a considerable signal can be controlled.
ck="window.open(this.src)" alt="Click to see larger image"/>
- What is a FinFET? What are the advantages and disadvantages of FinFET?
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- An article explains the working principle of the Wheatstone bridge
- What is an ac to dc transformer in circuit design
- Analysis of the basic principle of measuring resistance by bridge method
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- Causes and solutions for noise in digital Class D amplifiers
- Working principle/advantages/disadvantages/size of optical fiber
- Diode-based clipping circuit
- How does RCCB work?
- TDA7245 power amplifier circuit diagram
- TDA2613 power amplifier circuit diagram
- TDA2010 power amplifier circuit diagram
- TDA1519 power amplifier circuit diagram
- TDA1518Q power amplifier circuit diagram
- TBA820M power amplifier circuit diagram
- TA7282AP power amplifier circuit diagram
- TA7241AP power amplifier circuit diagram
- TA7232P power amplifier circuit diagram
- Wide dynamic range gain control amplifier circuit diagram
