Computer optical isolation interface circuit diagram
Source: InternetPublisher:风向西瓜 Keywords: Photoelectric isolation interface circuit diagram computer Updated: 2021/03/12
This circuit uses an optocoupler to isolate the computer from the peripherals. IC 2 is an optocoupler device; IC1 is a threshold comparator, and the threshold voltage is adjusted by P1; R2 and C1 form a low-pass filter to prevent IC1 from false triggering.
When TTL outputs the " 0" state, it lights up the primary of IC2, so its secondary is turned on, causing IC 1 to output the "1" state; otherwise, it outputs the "0" state.
- How to Build a Simple FM Radio Receiver on a Breadboard
- TA7792 Medium Wave Radio Circuit Diagram
- Wireless transmission of integrated TV signals for amateur productions
- FM transmitter in a matchbox
- Pocket Wireless Microphone
- WE800 FM/FSK 1~0.1 GHz Transmitter
- SB-200BRX superheterodyne receiving circuit
- Rolling code radio transmitter circuit (HSC360/TDA5100)
- MC33493/D OOK/FSK 928~902 MHz/434~315 MHz dual frequency transmitter
- RXM-433/418/315-LC-P AM Receiver Module
- How to design the switching circuit controlled by MCU?
- Computer host automatic temperature control circuit
- Relay interface circuit diagram of amateur wireless transceiver
- RS-232 computer power supply circuit
- HST Hall sensor application interface circuit diagram
- Photoelectric isolation high voltage power supply circuit
- Optical fiber interface circuit diagram
- Communication between 8031 microcontroller and PC-1500 computer
- Photoelectric isolation output switching circuit
- CAN interface circuit diagram
