Circuit diagram of adding visual judgment function to phone ringing
Source: InternetPublisher:红水杯 Keywords: Functional circuit ringing circuit diagram Updated: 2021/05/14
HA868 P/TSD telephone, connect a 10k ohm resistor between C301 and R301 . The other end of the resistor is connected to the positive terminal of the 1N4004 diode, and the negative terminal of the diode is connected to the positive terminal of the LED. As shown in the dotted line part in the figure. When the telephone is working, the current passes through R201 to make the LED light up. Due to the reverse bias of 1N4004, the current flow to the ringing circuit is blocked, and the modified part has no effect on the working indicator light. When ringing, the ring current is rectified by C301, 10K resistor and 1N4004 diode, and forms a loop through LED and D304. The LED flashes and glows. Since the shunt of the ringing indication is very small, the ringing has no significant effect.
ck="window.open(this.src)" alt="Click to see larger image" />
- Analysis of the reasons why bow-tie antennas are preferred over microstrip antennas for 5G antennas
- LM386 makes an AM radio
- Design and production of satellite receiver crash recovery circuit
- A cheap and easy-to-make infrared TV signal repeater
- MAX2360/MAX2362/MAX2364 I/Q 2000~1700 MHz/1000~800 MHz dual-band
- R5 433.92 MHz Receiver Module
- TR5100 FM 150~15 MHz transceiver
- TQ5638 KPCS CDMA/GPS 2090 ~ 1620 MHz Dual Mode Receiver
- T5761/T5760 ASK/FSK 870~868 MHz/928~902 MHz Receiver
- RCV420 4~20mA Precision Current Loop Receiver
- Mercedes-Benz 190E speaker circuit diagram
- Add computer control function circuit to ordinary electric fan
- Ringing switch start protection circuit diagram
- Cordless telephone ringing circuit diagram
- MAX666 voltage drop detection function circuit diagram b
- Intercom adds ringing function
- Circuit diagram for adding audio selective calling function to walkie-talkie
- Telephone ringing signal amplifier circuit diagram
- Light controlled ringing circuit diagram
