A cheap and easy-to-make infrared TV signal repeater
Source: InternetPublisher:黄土马家 Keywords: Infrared transponder Updated: 2024/11/11
At present, the radio and television network has upgraded the original analog signal to a digital signal, which needs to be demodulated by a set-top box before it can be viewed. Since a set-top box can only connect to one TV, if there are two TVs in a home, two set-top boxes are needed. For those that are not used at the same time, infrared repeaters can be used to share them. For this purpose, through searching for information, making, improving, and using it, the working principle is briefly introduced, see the attached figure.
The components used in this circuit are all easy-to-purchase common components with strong anti-interference, low cost, easy to make, and can work normally without debugging.
The circuit is based on the commonly used time base circuit NE555. The infrared receiving head needs to use an integrated high level in static state and a low level when receiving the remote control signal, otherwise the circuit cannot work properly. The infrared emitting diode is a common infrared emitting tube, and other components can be as given in the figure. Its working principle is that the infrared integrated receiving head receives the infrared signal sent by the remote control to control the conduction and cutoff of the Q1 tube to achieve whether the IC is powered. Once the IC is powered, it will generate a 38kHz signal by itself, and output a high level through the ③ pin to turn on Q2, and the infrared emitting tube sends out an infrared signal.
It is connected by a universal board, and can be powered on for testing after checking the circuit diagram. After it is normal, place the receiving head in the room, extend the transmitting tube with a lead to the vicinity of the infrared receiving window of the receiver, and then the set-top box can be remotely controlled.
- Why should RS-485 transceivers be terminated? How to terminate?
- Application of GaN power devices in array radar transceiver systems
- LM386 makes an AM radio
- Change the frequency of the campus radio
- Pocket Wireless Microphone
- MGCT02 I/Q TDMA/AMPS l900/900 MHz Dual-Band Dual-Mode Transmitter
- Eight-way remote control transmitter circuit using CS901
- RF2909 GMSK/QPSK/DQPSK/QAM 915 MHz Transmitter
- T5761/T5760 ASK/FSK 870~868 MHz/928~902 MHz Receiver
- F05A/B/C Series AM 433/315 MHz RF Transmitter Module
- Infrared control dimming circuit
- USB communication circuit
- Indoor unit communication circuit
- Infrared anti-theft alarm circuit one b
- Infrared sensor faucet automatic handwasher circuit
- Infrared warning switch
- Sanmo brand GT-5 infrared quartz electric heater circuit diagram
- DSX-20A type infrared high temperature electronic disinfection cabinet circuit diagram
- Infrared multi-channel programming remote control
- Infrared blind cane circuit diagram
