5V to 12V switching power supply circuit diagram designed using MAX761
Source: InternetPublisher:常思一二 Keywords: Switching power supply circuit diagram MAX761 voltage detection Updated: 2021/11/03
Shown in the figure is a 5V → 12V boost power supply composed of a high-efficiency, low-power boost DC converter MAX761 and several peripheral components. Its characteristics are: conversion efficiency is 86%; quiescent current is 110μA; it has low battery voltage detection function. R3 and R4 in the figure are battery voltage detection dividing resistors. Generally, it can be calculated according to the empirical formula: R4=R3(VTPIP/1.5-1 ) to calculate, VTPIP is the detection trigger voltage.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Sharing layout and tips for multi-rail power supply design
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Basic connection circuit of signal and power supply composed of ISOll3
- Driving circuit that controls LED brightness using PWM signal
- Simple and practical LED lamp driving circuit
- Low cost and high performance LED constant current power supply
- Charging control circuit made by solar energy
- CNC regulated power supply production
- Adjustable voltage power socket
- Excellent performance household inverter power supply circuit
- 24V power supply pure flat display high voltage power supply circuit diagram
- Portable device charging power circuit design
- 5V to 12V switching power supply circuit diagram designed using MAX761
- Battery Charger Voltage Detection Relay Circuit
- Color display switching power supply circuit diagram using STK7308
- New switching power supply circuit diagram using MAX761
- High-efficiency switching power supply circuit diagram with 300V output
- Half-bridge pulse width switching power supply circuit diagram
- Half-bridge mode switching power supply circuit diagram
