High operating voltage voltage stabilization circuit diagram
Source: InternetPublisher:奥特man123 Keywords: Circuit diagram voltage stabilizing circuit Updated: 2020/06/21
It can be seen from the voltage equation Ue=Ut+Ur+Ua that the voltage Ut on the transistor will determine the maximum value of the output voltage Ua. At the same time, there should be Ur》2V. The voltage Ut depends on the selection of the voltage regulator value Uz. The selection of resistor R in Figure a must satisfy the boundary condition of Iz=Ib+Ir or the principle of Ir≈10·Ib. This circuit is suitable for situations where the integrated circuit has a higher operating voltage. When the voltage is lower, such as Ue=5V, the circuit in Figure b should be used. The voltage stabilization value of the voltage regulator tube should be at least 4V higher than the output voltage Ua. The selection of resistor R is the same as that of circuit a.
ck="window.open(this.src)" alt="Click to see larger image" />
- How about the boost converter TPS61299?
- Simple and practical LED lamp driving circuit
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- LED rechargeable flashlight circuit diagram
- How to use SBR to improve power conversion efficiency
- A simple positive and negative power supply circuit
- Integrated regulated power supply with continuously adjustable output voltage
- 3~15V 10A adjustable voltage regulated power supply
- Car Audio Power Supply
- Homemade home inverter circuit diagram
- DC 12V to AC 100V inverter power supply circuit design
- Power supply circuit design optimized for digital light projectors
- Power circuit a composed of intelligent thyristor modules
- Laser power circuit
- Super Class A power amplifier power circuit
- led drive power circuit
- Music power circuit
- Common power circuits and applications 08
- Common power circuits and applications 05
- Inverter power circuit
