Current limiting high current voltage stabilizing circuit diagram
Source: InternetPublisher:难得正经 Keywords: Circuit diagram voltage stabilization circuit WIDTH Updated: 2021/08/24
The selection of resistors R1 and R2 in the figure must meet the condition of R2》5·R1. For example, R1=0.2 ohm, R2=1 ohm. The actual mid-apparent current requires R1 to be between 0.1 and 2 ohms, and Ube=Ud has the relationship UR1=UR2, so I2 is about 5 times smaller than I3, the total current I1=I2+I3≈I4, ignoring the base current of the transistor, Then I3 is equivalent to the regulation current of the integrated circuit IC. For transistors with large current, resistor R3 can be selected between 10 and 20 ohms. For small current transistors, 100 ohms can be selected.
ck="window.open(this.src)" alt="Click to see larger image" />
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Introduction and principle analysis of switching regulated power supply
- Visible laser digital control modulation driver
- LED rechargeable flashlight circuit diagram
- A simple positive and negative power supply circuit
- A small and easy-to-make fast charger
- A novel and practical DC low voltage stabilized power supply
- Constant current charger using light emitting diode as voltage regulator
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- A low-cost, high-reliability battery charger for electric vehicles
- Small (2~3 meters) neon light electronic transformer circuit diagram
- Fuse/thin wire transmitter circuit diagram
- MAX1870A - Typical Operating Circuit
- MAX9489 charging circuit diagram
- All crystal transistor inverter circuit
- Hall switch collector output interface circuit diagram
- Positive temperature sensor and coefficient resistor circuit diagram
- Circuit diagram for driving 4 white LEDs based on charge pump
- Circuit diagram of using NCP3065/NCP3066 to drive LED
- Simple signal generator for signal tracing
