How to ensure that the power supply works efficiently for a long time?
Source: InternetPublisher:zht24 Keywords: power supply Updated: 2021/02/06
In order to ensure the stability of the power supply for long-term operation, the power supply must be comprehensively tested and analyzed. There will be dozens of test items. It is necessary to select the appropriate test instrument according to the test items to maximize the performance of the instrument. In terms of electrical parameters, Power analyzers are used for energy efficiency and harmonic testing, and oscilloscope recorders are used for isolation testing, multi-channel synchronous analysis, durability testing, and abnormal capture.
Test equipment—ZDL oscilloscope
The ZDL6000 oscilloscope recorder comes standard with 8 board card slots. Each input channel is insulated from each other, which saves power users a large number of high-voltage differential probes. It can provide a variety of input boards and channels such as voltage, current, temperature... Up to 128CH, providing the best solution for customers to observe waveform timing and find abnormal signals.
1. Oscilloscope recorder—drive timing test
The general method of testing drive timing is to use an oscilloscope and a differential probe to test the Vgs and Vds of the MOS. Use a current probe to test the inductor current. You can observe the corresponding drive signal quality and inductor current working mode. If you use an oscilloscope recorder to test, Then there is no need for a differential probe, the test is more accurate and more convenient, as shown in Figure 1.
Figure 1 Drive timing test
2. Oscilloscope recorder—abnormal capture and durability testing
Exception capture: When the power supply product is running for a long time, it is unknown what problems will occur. The oscilloscope cannot set the trigger conditions and it is not easy to capture the exception. However, after using the oscilloscope to record the waveform, you can review it and effectively capture the abnormal waveform;
Endurance testing: Power supply products require frequent on/off experiments. Thousands of times may only cause one failure, so a recorder is required to record the product for a long time to analyze the stable performance of the product.
Figure 2 Multi-channel synchronous endurance test
3. Component temperature rise test
Abnormal temperatures in key parts of the equipment can lead to reduced equipment performance or even damage. Therefore, temperature rise testing is an essential item in the product development process. ZDL6000 can be used to flexibly combine voltage acquisition cards, 16-channel cards, temperature acquisition cards and other boards for simultaneous measurement. For example, in the temperature rise test, a 100M card and a temperature card can be assembled to synchronously test the device's operating voltage, current, and temperature rise of key parts.
Figure 3 Component temperature rise test
- How about the boost converter TPS61299?
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Single-power supply circuit for ISO122P/ISO124
- Principles and precautions of active discharge circuit
- 3~15V 10A adjustable voltage regulated power supply
- LM317T voltage regulation adjustable circuit diagram explanation
- Circuit diagram explanation: simple switching power supply circuit diagram
- Summary of key points of switching power supply PCB layout, worth collecting!
- How to ensure that the power supply works efficiently for a long time?
- How to judge the quality of LED power supply?
- Which power supplies should be chosen for collection?
- Power phase failure display circuit
- Miniature polarity reversing power supply composed of MAX1721
- Medical infusion alarm circuit
- Power outage alarm circuit
- AD597 functional diagram
- Power circuit b composed of intelligent thyristor modules
