AD597 functional diagram
Source: InternetPublisher:同住地球村 Keywords: AD thermocouple BSP power supply Updated: 2021/02/24
High temperature measurements often require thermocouples as temperature sensing elements. Due to the nonlinearity of the thermocouple output,
linear compensation is required when amplifying the thermocouple output. AD594-597 is a special amplification, linear compensation and control
circuit for thermocouples.
AD594/595 are thermocouple signal amplification and cold junction compensation monolithic integrated circuits. Their functional principles and pin definitions
are the same. The difference is that AD594 is equipped with a J-type thermocouple and AD595 is equipped with a K-type thermocouple. The output is low impedance, the voltage
output is 10mV/oC, and the resolution is 1℃. The working power supply range is t5v~±15V.
AD596/597 is a thermocouple signal amplification and temperature control
circuit. They have two models with different suffixes, namely
AD596AH/597 AH and AD596AR/597AR.
The functional principles and pin definitions of the two models are different,
but the functional principles and
pin are the same. Mainly The difference is that the AD596 is equipped with a J-
type thermocouple, and the AD597 is equipped with a K-type thermocouple . The output
is - 10 rv/cC; the working power supply range is +5~
+30V. The AD594/595 functional diagram is shown in Figure 1-21
. AD 596/597 functional diagram is shown in the figure
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- How are diodes made using semiconductors?
- Analysis of the flow direction of transistor current
- Which one is better, NPN or PNP transistor?
- How to calculate the value of capacitors in parallel?
- Working principle/advantages/disadvantages/size of optical fiber
- Why use PWM? What are its advantages?
- Make a flameless electronic candle using simple electronics and LEDs
- What types of force sensors are there?
- LED Night Light
- AD power supply circuit design experience, worth collecting
- AD8202 two-stage system structure application circuit diagram
- AD7730 internal functional block diagram and pin function diagram
- AD594-595 functional diagram
- Introduction to the high-precision ±5V reference source AD586
- AD2S80A typical connection circuit
- Permanent magnet servo motor field oriented control
- AD590 circuit diagram
- Electronic transformer circuit
- Changfeng KAB-11, KAD-12, KAD-18 wall ventilator circuit diagram
