Timing socket principle circuit diagram
Source: InternetPublisher:武林萌主 Keywords: socket circuit diagram Updated: 2020/07/11
As shown in the figure is the timing control circuit, and CZ is a power socket controlled by timing .
The mains power is stepped down through the transformer, bridge rectified, and filtered to obtain 12V voltage for circuit operation. 555 is connected to form a single stable circuit, 3DJ6F is connected to form a constant current source to charge the timing capacitor C, and the 555 output is connected to the relay J1 line package to achieve switching control. To start, press the switch AN to start the timing, so 555 outputs high level and the timing starts. If K is at the "1" position at this time, J1 is in the timed release state, and K is at the "2" position, which is the timed suction state. After the timing starts, 3DJ6F charges C with a constant current until the voltage on C rises to 8V and the timing ends. C is discharged through the 7th pin of the 555, and the 555 output becomes low level to cause J2 to change state. The CZ socket can be controlled by scheduled power on (K connected to "2") or scheduled power outage (K connected to "1").
W is a timing adjustment potentiometer with an adjustable range of about 150 minutes. W can use an exponential (Z-type) potentiometer, making short timing easy to achieve. The relay can be used in the JQX-4F-DC12 type, with a coil DC resistance of 450 ohms, a DC working voltage of 12V, a pull-in voltage of less than 9V, a pull-in current of about 25mA, and a contact capacity of AC 220V/3A. The power transformer can be a small transformer for signal lights with 220V/10V specifications.
W can be calibrated with a standard clock and time scaled to facilitate presetting the timing time.
- Car ice warning circuit sharing
- How to set up a cheap beam break sensor control distance scene using a reflector
- DC motor drive circuit composed of L293D
- Working principle of one Xipu STR soft starter controlling two motors
- Methods for Eliminating Noise of Brushed DC Motors
- Design and analysis of the principle of automatic power-off switch during power outage
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Temperature control circuit design and analysis
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- A novel and practical power line anti-theft and cutting alarm circuit
- Multi-channel patrol detection control circuit b
- Ringtone control circuit
- Digital camera flash control circuit
- Switching regulated power supply circuit
- Electromagnet control circuit
- DC voltage stabilizing circuit and zero-crossing detection circuit in the indoor unit control circuit of Hisense KFR-25GW-06BP inverter air conditioner
- Multi-pole leakage protector circuit b
- Detection and control circuit of electromagnetic stove
- Forward and reverse control circuit of micro DC motor b
- Apply LOGO! Electric gate control circuit b
