Digital tube extinguishing signal circuit diagram
Source: InternetPublisher:containsmachine Keywords: Signal circuit digital tube circuit diagram WIDTH Updated: 2021/07/30
In a multi-digit display, in order to emphasize certain numbers, an extinguishing signal is added to this circuit to make the digital tube light up or darken. The principle is to use Q1 and Q2 to reduce the cathode voltage of the digital tube from the normal value of 200V to 100V, making the digital tube dim. The control signal is input from the base of Q2. When the fire extinguishing signal is 0V, Q2 is cut off, and the cathode voltage of the digital tube is 200V. When the fire extinguishing signal is 2V, Q2 is turned on and the cathode voltage drops to 100V.
ck="window.open(this.src)" alt="Click to see larger image" />
- One-digit display
- Lighting audio control circuit
- Desk lamp dimming soft switch circuit
- Fluorescent lamp electronic ballast circuit 11
- Shock resistant soft start constant current LED lighting circuit
- Electronic rapid starter for fluorescent lamps
- SH-803R holiday lights ASIC
- Touch/wireless remote control dimmer light circuit diagram
- Reverse polarity drive circuit
- Night target display circuit diagram
- Hardware circuit diagram of ultrasonic range finder
- LA4475 power amplifier circuit diagram
- LA4185 power amplifier circuit diagram
- AN7168 power amplifier circuit diagram
- AN7161N power amplifier circuit diagram
- Constant voltage current limiting charger circuit diagram
- Blind multimeter circuit diagram
- MAX1870A - Typical Operating Circuit
- Circuit using NCP1216 to drive LED
- MAX16834 driver LED circuit diagram
