Blind multimeter circuit diagram
Source: InternetPublisher:小胖友 Keywords: Multimeter circuit diagram WIDTH Updated: 2021/05/15
A small electronic horn is used to generate sound when the measured DC voltage differs from the reference voltage, which is determined by the linear wirewound potentiometer R7. Adjust R7 sound to null, then read the set braille point to get the measured voltage value . Use PNP silicon transistors such as BC177 or BC187.D5.
- Isolated 4-20mA instrument loop (RTD) circuit composed of RCV420
- Circuit Fault Tracker
- Multi-speed current test circuit of transistor HFE
- How to Simplify Analog Front-End Design for Heart Rate Monitors
- Using a Remote Control to Make a Crystal Oscillator Frequency Tester
- How to Use a Radio as a Metal Detector
- AC equivalent amplifier circuit
- Light Detection 4 to 20mA Current Transmitter Circuit
- Directly coupled push-pull power amplifier circuit
- High-speed gain programmable amplifier circuit
- AN7173NK power amplifier circuit diagram
- Subwoofer crossover amplifier circuit diagram
- Ringing switch start protection circuit diagram
- Switching power supply output part circuit diagram
- Constant voltage current limiting charger circuit diagram
- Three-phase three-wire active energy meter direct connection type
- Practical circuit diagram based on LT3468 dual output boost LED driver
- MC4024P simply constructs a signal generator circuit diagram
- Gain adjustable test equipment isolation amplifier circuit diagram
