Light control circuit principle circuit diagram
Source: InternetPublisher:jikai233 Keywords: Light control circuit circuit principle circuit diagram Updated: 2021/08/18
Working principle: The working principle of the application circuit of this device is shown in the figure. During the day, due to strong light, the internal resistance of the photoresistor RG is very small. At this time, a large current flows through RG, causing the transistor VT to saturate and conduct. After VT is saturated, the voltage at the ④ terminal of the controller DM is much lower than 1.6V. Therefore, DM is internally cut off and the lighting lamp H cannot light up.
When night comes, the light dims, the luminous flux shining on RG weakens, the internal resistance of RG becomes larger and larger, and the internal circuit of controller DM gradually opens, so that current flows through the lighting lamp H to make it glow. This circuit is a soft start mode, that is, the filament of the lighting lamp H gradually transitions from red to incandescent state, and it is not easy to flicker when the filament is red.
ck="window.open(this.src)" alt="Click to see larger image" />
- DIY a hat with a programmable LED display
- IRS2530D electronic ballast circuit diagram
- LED Signage with RS232 Port Operation Guide
- Laser detection and indicating device system circuit design
- One of the circuits that control one light in multiple placesb
- Gas and smoke alarm circuits with intermittent alarms
- Economical and practical delay light circuit
- Photoelectric adjustment circuit
- Four color light circuit
- Reverse polarity drive circuit
- Circuit diagram of a voltage doubler rectifier electronic ballast
- Remote control circuit diagram composed of CSJ-T300B and CSJ-R02B
- Cycle timer circuit diagram with start and stop preset functions
- High-precision nanoamp level current generator circuit diagram
- Household small TV transmitter circuit diagram
- Street light control circuit 6
- Principle of half-wave rectifier circuit
- Internal circuit principle of LM386
- Principle of high current switching regulated power supply circuit 02
- Charge pump circuit principle no-load circuit diagram
