High-precision nanoamp level current generator circuit diagram
Source: InternetPublisher:念慈菴 Keywords: High precision current generator circuit diagram generator circuit Updated: 2021/10/18
In practical applications, many special measurement circuits require nanoampere-level high-precision current as a benchmark, and it is difficult to produce them in amateur situations. This article introduces a high-precision nanoamp level current generator circuit for enthusiasts to make their own, as shown in the figure.
This circuit is a microcurrent constant current source. In order to enable the current value to be continuously changed at will, a multi-turn (10-turn) potentiometer is used as a voltage divider to divide the reference voltage and the current value can be read directly. Then through the current shifting resistors R3 and R4, a wide range of tiny currents can be generated.
The VT tube in the circuit uses a MOSFET tube with very small gate current. The reference voltage is 1V. Adjust the potentiometer RP1 so that RP2 generates a +1V voltage when the current is adjusted to the maximum. RP3 is used for offset adjustment and also improves the fixing accuracy of RP2.
- Transformerless Switch Mode Power Supply Circuit Diagram Explanation
- What effect does the copper coating on the bottom of the inductor have on the power supply?
- How to Make a Soft Latch Circuit
- Benefits of Wide Bandgap Technology for Power Converters
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Using Lead-acid Battery as Power Source for Walkman
- Basic circuit description of adjustable voltage regulator LM317
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- The constant current source composed of two transistors can drive high power
- LNK304 non-isolated LED light string driver circuit
- Various signal generator circuits
- Siren signal generator circuit
- Quantitative pulse generator circuit
- Square wave generator circuit
- Multifunctional CNC waveform generator circuit diagram
- Ramp generator circuit diagram
- frequency modulation generator circuit
- Signal generator circuit with small distortion
- Single stage sound signal generator circuit
- Universal signal generator circuit for radio recorders and televisions
