LM317 adjustable integrated voltage regulator circuit diagram
Source: InternetPublisher:睡不醒的小壮 Keywords: Circuit diagram LM317 integrated voltage stabilizing circuit Updated: 2021/02/23
As shown in the figure, LM317 is a common adjustable integrated voltage regulator with a maximum output current of 2.2A and an output voltage range of 1.25~37V. The circuit connection is as follows:
ck="window.open(this.src)" alt="Click to see larger image" />
The voltage reference between pins 1 and 2 is 1.25V. To ensure the output performance of the voltage regulator, R1 should be less than 240 ohms. Changing the resistance of R2 can adjust the regulated voltage value. D1, D2 are used to protect LM317 .
- How to Make a Soft Latch Circuit
- 220V Remote Load Monitor
- What kind of circuit is a voltage regulator circuit?
- Use pulse width modulation to get a precise output voltage
- Switching power supply circuit composition and function introduction of each part
- Principles and precautions of active discharge circuit
- Voltage-current converter constructed with XTR110
- Dynamic power supply for power amplifier controlled by thyristor
- A small and easy-to-make fast charger
- The production of adjustable voltage-stabilized power supply composed of LM317
- Excellent performance household inverter power supply circuit
- Power circuit of STR5412
- Portable device charging power circuit design
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- audio power circuit
- Karaoke light controller circuit (1)
- Power circuit for home appliance repair
- Common power circuits and applications 08
- Basic application circuit of LM31705
- LM317 extended current circuit diagram
