Voltage-current converter constructed with XTR110
Source: InternetPublisher:aytwartoofyoroo Keywords: Converter Updated: 2024/08/16
As shown in the figure, when the output current exceeds 40mA, the internal 50Ω resistor (R9) of XTR110 needs to be replaced by an external resistor REXT, and REXT is connected between pins 13 and 16. REXT = R9 (original span / required span). For example, in the figure, the original span of XTR110 is 20mA, and the required span is now 10A, R9 = 50Ω, then REXT = R9 = 50 × (20/10000) = 0.1Ω.
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- How to Make a Soft Latch Circuit
- Practical and convenient fax machine power supply control circuit
- Driving circuit that controls LED brightness using PWM signal
- Dynamic power supply for power amplifier controlled by thyristor
- Adjustable regulated power supply with current limiting protection
- Car power 1.5V-12V six-speed converter
- Electric bicycle battery charger circuit
- Adjustable voltage regulated power supply circuit
- Homemade home inverter circuit diagram
- Portable device charging power circuit design
- EPSON PHOTO 830U printer power circuit
- Power circuit with smoothing filter capacitor
- Using magnetic transducer as position signal detection device circuit
- Connection circuit diagram of external A, D converter
- Sensor displacement current to voltage converter
- Microprocessor power supply circuit diagram using flyback converter
- V/F converter
- Voltage frequency converter with integrator
