Capacitor Buck Regulator Power Supply Circuit Diagram
Source: InternetPublisher:super_star Keywords: Capacitor step-down power supply circuit diagram step-down voltage regulator voltage regulator power supply Updated: 2020/02/28
If the capacity of capacitor C1 is doubled, the output current can be nearly doubled, but it cannot be too large. If the output ripple is large, an analog voltage regulator such as 7805/317 can be connected behind it. Changing the value of R3 can change Output voltage. The marked output current is the maximum output current. The triac B1 can be 1A.
This power supply can be short-circuited. If you can ensure that the capacitor C1 is connected to the live wire, you can touch it with your hands. Originally, this power supply was provided for small electrical appliances that people do not touch. As long as the non-polar capacitor C1 has enough voltage resistance, there is no problem in long-term use. From the principle Technically speaking, this is a parallel voltage stabilizing circuit with an input voltage of 220V. The voltage drops across C1. If the output current is large, the capacity of C1 can be increased. I once increased it to 2UF and it can be used normally. I have also tested 4UF. , when pulling out and plugging in the plug, the spark was too big, so I stopped using it. I used the picture 1, and the thyristor and 431 were not damaged. In fact, since E1 is 470 times larger than C1, even at the moment of switching on, the AC The peak value is more than 300 volts, and there will be no high voltage on E1. The power is easy to calculate. The capacitive reactance of a 1UF capacitor to 50HZ is 3.15k. The output current is estimated: 200V/3000 ohms, and the current is about 60MA. If it is half-wave rectified , the current is only half. About 30MA.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Transformerless AC-DC constant current LED driver circuit
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Detailed explanation of 5v charger circuit diagram
- Miniature polarity reversal power supply using MAX1721
- Boost drive circuit composed of RT8450
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Excellent performance household inverter power supply circuit
- DC 12V to AC 100V inverter power supply circuit design
- Capacitor step-down power-saving circuit a
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- KGDS type single-phase low temperature iron plated power supply circuit
- One of the transistor stabilized current power supply circuits
- Full-wave capacitor step-down rectifier circuit b
- Full-wave capacitor step-down rectifier circuit a
- Diamond differential input power amplifier power circuit
- Karaoke light controller circuit (1)
