Capacitor step-down power-saving circuit a
Source: InternetPublisher:消失的歌 Keywords: Capacitor reduces voltage and saves electricity Updated: 2020/07/31
Generally speaking, the stairs, corridors, bathrooms, kitchens, etc. in the home do not need very bright lighting. Just install a low-power light bulb . This section
introduces a capacitor energy-saving lamp that can turn a high-power bulb into a low-power one, extend the service life of the bulb, and improve the power factor of the circuit.
The picture shows the circuit diagram of the capacitor voltage reduction and power saving circuit. Its working principle is to use capacitors as voltage-reducing components in series in the light bulb circuit to
reduce the working voltage of the light bulb, thereby reducing the power of the light bulb. Figure 10-18a shows a series capacitor C and a single
switch SA2 added to the original circuit . SA2 is used to control whether capacitor C is connected or not. Figure 10-18b is a connection method controlled by a single-pole double-throw switch SA
. Both of these connection methods can make the light bulb have two working states. A series of capacitors makes the light bulb have low power; a short-circuited capacitor makes the light bulb glow normally. Figure
10-18c is just a capacitor in series with the original circuit , and the light bulb can only work in a low power state.
When installing, install the capacitor next to the pull-wire switch. When wiring, the wires and capacitors should be welded together, and the joints should be wrapped with tape
to ensure safety.
Capacitors should be selected with a rated voltage above 400V, and electrolytic capacitors cannot be used.
The capacitance of the series connected capacitor when the power efficiency of commonly used light bulbs of various powers is about Sw
- DIY a hollow clock
- Design and analysis of a simple zero-crossing power regulator circuit
- Using CD4017 to form an analog pendulum circuit
- Triangle, Yuanling, Gold CFXB type double lamp rice cooker circuit diagram
- Electric curtain circuit a Household appliance circuit
- Debei brand SC45STIV, BC-347 refrigerator circuit
- Delta VFD-P inverter typical application circuit
- Hot and cold water dispenser circuit household appliance circuit
- Kana brand BD-130 refrigerator circuit
- Monolithic integrated circuit radio
- Power limit and power saving circuit
- Relay power saving circuit 5b
- Relay power saving circuit 4b
- Use CD4013 to make touch delay energy-saving lamps
- Energy-saving three-phase asynchronous motor phase failure protection circuit
- Capacitor Buck Regulator Power Supply Circuit Diagram
- DC-DC converter diagram for boosting 2 batteries to 3.3V, 5V, 12V
- Floor lamp power saving control circuit
- Given voltage and speed negative feedback circuit
- Capacitor step-down economical light circuit
