LM317 adjustable integrated voltage regulator circuit diagram
Source: InternetPublisher:containsmachine Keywords: Circuit diagram LM317 integrated voltage regulator circuit WIDTH Updated: 2020/05/08
As shown in the figure, LM317 is a common adjustable integrated voltage regulator with a maximum output current of 2.2A and an output voltage range of 1.25~37V. The circuit connection is as follows:
ck="window.open(this.src)" alt="Click to see larger image" />
The voltage reference between pins 1 and 2 is 1.25V. To ensure the output performance of the voltage regulator, R1 should be less than 240 ohms. Changing the resistance of R2 can adjust the regulated voltage value. D1, D2 are used to protect LM317 .
- A very convenient small power supply circuit to share
- 220V Remote Load Monitor
- Introduction and principle analysis of switching regulated power supply
- Step-down power supply for driving relays
- Op amp power supply decoupling bypass measures
- The constant current source composed of two transistors can drive high power
- Switching power supply circuit composition and function introduction of each part
- Miniature polarity reversal power supply using MAX1721
- Car power 1.5V-12V six-speed converter
- Practical constant current charger-----Constant current charger
- Photoelectric control digital tube display circuit
- LA4261 power amplifier circuit diagram
- CD4520, CD4511, CD4067 digital display automatic inspection circuit diagram
- HA1377 power amplifier circuit diagram
- AN7112 power amplifier circuit diagram
- 75 watt audio amplifier circuit diagram with load line protection
- SPT1141/1151 multi-function switch controller circuit diagram
- EW-8W electronic ballast circuit diagram
- Nickel cadmium charger circuit diagram
- Basic application circuit of LM31704
