Step-down power supply for driving relays
Source: InternetPublisher:天天都吃好吃的 Keywords: Step-down power supply relay Updated: 2024/10/08
When developing some electronic and electrical circuits, it is often necessary to use DC relays to execute automatic control circuits. The low DC voltage supplied to the relay is generally supplied after voltage reduction and rectification by a transformer, which is costly and complicated for some simple electronic circuits. If a resistor and a diode are connected in series to rectify the DC output, and then the DC voltage obtained after capacitor filtering and voltage stabilization is directly supplied to the relay coil winding working voltage, it is very easy and convenient. Of course, 4 diodes can also be connected in series to form a bridge rectifier circuit, and the effect will be better. See the figure for the wiring of circuit components.
Please pay close attention to safety!
- 5 Converter Topologies for Integrated Solar and Storage Systems
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Driving circuit of switching power supply field effect tube
- Introduction and principle analysis of switching regulated power supply
- Basic circuit description of adjustable voltage regulator LM317
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- An ultra-low output voltage regulator
- LM317 regulated power supply
- Circuit diagram explanation: simple switching power supply circuit diagram
- Power circuit of STR5412
- Power circuit of LBO-522 dual trace oscilloscope
- Voltage stabilization control circuit in power circuit
- Simple dual-channel variable DC power supply circuit
- Music power circuit
- Telephone power circuit
- AC-DC conversion power supply-inverter power supply circuit
- 5V, 7.5V, 48V power circuit
- COMPAQ 420G type SVGA color display power supply circuit
- Maintenance and experiment of multi-purpose power circuits
