TDA2009 single power amplifier circuit diagram
Source: InternetPublisher:三岁就很酷 Keywords: Power amplifier circuit diagram single power supply power amplifier WIDTH Updated: 2020/11/28
I have always wanted to do a morning exercise machine, but I have been unable to find a high-power single- power amplifier . Because the morning exercise machine is battery-powered, I have been thinking about it for several months. Finally, I found a TDA2009 single- power amplifier IC. Now I am working with it. Please share the application circuit diagram of TDA2009.
TDA2009 is a common and affordable high-fidelity power amplifier integrated block. Rated power is 2×10W. The power supply voltage is 8~28V. The maximum output current is 3.5A. Has overheating protection circuit. (2×10W, THD=0.5%)
According to the author's several sets of power amplifiers built using this chip, the effect is still very good. It has been used to this day for several years without any failures. Of course, as introduced in the "Ground Wire Design Tips" chapter, the premise is that the ground wire design must be reasonable. In addition, although it generates very little heat, you still need to pay attention to heat dissipation. The circuit diagram is as follows:
ck="window.open(this.src)" alt="Click to see larger image" />
- Make the most beautiful sound with the least money
- Making a Simple Tube FM Radio
- Telephone volume amplifier circuit
- The fun of making ISD1820 voice recording box
- Using Shuguang 350C tube to make tube amplifier
- 1OW audio power amplifier circuit using UPC1238
- Improved Marantz 7-tube preamplifier circuit
- LM4903/4905 differential input audio amplifier circuit
- LMl876 is used to assist the audio power amplifier circuit
- Stereo amplifier circuit with Av=200 (gain) composed of LM1877
- HA1377 power amplifier circuit diagram
- AN7149N power amplifier circuit diagram
- Common double-tube energy-saving lamp circuit schematic diagram
- MJE13005×2 electronic ballast circuit diagram
- EW-8W electronic ballast circuit diagram
- MAX1870A - Typical Operating Circuit
- Transistor light meter circuit diagram
- Spike peak measurement circuit diagram
- PLC circuit diagram of CNC machine tool
- Multi-waveform signal generator circuit diagram
