Stereo amplifier circuit with Av=200 (gain) composed of LM1877
Source: InternetPublisher:消失的歌 Keywords: Stereo amplifier circuit Updated: 2024/09/11
As shown in the figure, it is a stereo amplifier circuit with Av=200 (gain) composed of LM1877. Two input audio signals are coupled to the input terminals 6 and 9 of LM1877 by two 0.1μF capacitors respectively, and then output from the 2 and 13 pins after amplification, and sent to the load resistor RL respectively. The amplifier gain is determined by the ratio of the 100kΩ resistor in the feedback loop between the 2 and 7 pins and the 510Ω resistor at the inverting input terminal 7 pin, so the amplifier gain (Av) is about 200. The two 1MΩ connected to the 1 pin are used to set the DC bias operating point of the amplifier, and at the same time, they form an input high-pass filter with two 0.1μF coupling capacitors respectively. The 2.7Ω resistor and 0.1μF capacitor connected in parallel with the two load resistors RL are used to filter out high-frequency noise.
- Echo Dot speaker intelligent control system solution
- 6P3P parallel 20W power amplifier experiment
- Homemade high quality preamplifier tone circuit
- Experiment of 2-in-1 single-ended Class A tube amplifier
- Production of 6n3 Pushing 6p1 Single-ended Tube Amplifier
- Bridge output audio power amplifier circuit composed of LM1876
- Single power supply audio power amplifier circuit composed of LM3875
- LM4906 Audio Power Amplifier Circuit
- Tube single-ended class A 300B power amplifier circuit
- LM4819 high gain audio amplifier circuit
- Seven basic analog circuits
- Field effect transistor sound control amplifier circuit
- Highly stable thermocouple temperature measurement amplifier circuit composed of OP07
- Broadband amplifier circuit
- High output voltage amplifier circuit
- Multistage DC coupled amplifier circuitb
- Two-stage DC-coupled amplifier circuit
- Positive-phase AC amplifier circuit that can increase input impedance 10 times
- Common drain amplifier circuit
- In-phase stereo amplifier circuit
