Tone and volume adjuster circuit diagram for stereo equipment
Source: InternetPublisher:傻阿乐 Keywords: Circuit diagram stereo volume adjuster WIDTH Updated: 2021/05/20
The degree of treble and bass boosting or lowering and the volume adjustment of this circuit are similar to those of the previous circuit. The volume adjustment part connects the reference potential point of pin 4 and pin 2, so the degree of tone reduction at pin 3 and pin 6 is different at this time. If a network related to the same frequency is connected between pin 3 and pin 6, an output signal that varies with the volume level can be obtained at its tap. This signal can control the audio equipment of the left and right channels respectively.
ck="window.open(this.src)" alt="Click to see larger image" />
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- Make a high-quality DAC board
- Experiment of 2-in-1 single-ended Class A tube amplifier
- Sugon New Tube 2A3C Single-ended Tube Amplifier
- Biliary duct 2A3C Class A amplifier
- Electronic toy dog
- 6AS7 tube amplifier
- Stereo tube power amplifier
- Class A power amplifier circuit with an output power of 18W
- LMl876 is used to assist the audio power amplifier circuit
- LA4557 power amplifier circuit diagram
- LA4497 power amplifier circuit diagram
- HA1377 power amplifier circuit diagram
- Subwoofer crossover amplifier circuit diagram
- AC voltmeter circuit composed of milliammeter
- MAX9489 charging circuit diagram
- Electric fan induction braking circuit diagram
- Hall switch collector output interface circuit diagram
- MAX16834 driver LED circuit diagram
- Signal generator circuit diagram
