AC voltmeter circuit composed of milliammeter
Source: InternetPublisher:闪电杰克 Keywords: AC voltmeter WIDTH resistor Updated: 2021/02/15
By adding a few semiconductor diodes to the milliamp meter , you can measure AC voltage and turn it into an AC voltmeter , as shown in the figure VD1 and VD2 form a half-wave rectifier. The four resistors in the figure are separate multiplication resistors: the multiplication resistors in figure b are connected in series, and their effect is the same as that in figure a. The " * " terminal in the figure is the common terminal. No matter what voltage is measured, one of the two test leads must be connected to the " * " terminal .
- Simple Digital Oscilloscope
- Temperature monitor
- Oscilloscope-type ESR tester
- Analog Capacitor ESR Tester
- Equivalent Series Resistance and Low Resistance Tester
- How to Accurately Measure Current and Voltage in GSM Systems
- Two-wire and four-wire resistance measurements
- 555 Line Output Transformer Short Circuit Detector
- Electrolytic capacitor activator
- Thyristor Tester Production
- LA3225T LA3226T audio preamplifier circuit diagram
- AN7161N power amplifier circuit diagram
- 8W audio amplifier integrated circuit
- Crystal oscillator 80mW FM transmitter production circuit diagram
- Field output circuit: TDA3654 circuit diagram
- Corridor light control circuit diagram
- Hall switch collector output interface circuit diagram
- Positive temperature sensor and coefficient resistor circuit diagram
- 50W white LED headlight driver circuit diagram based on LT3755
- Multi-waveform signal generator circuit diagram
京公网安备 11010802033920号
