Active continuous audio filter
Source: InternetPublisher:JFET Keywords: Power supply other power circuits audio Updated: 2021/06/02
![Active continuous audio filter](http://www.eeworld.com.cn/circuit/upload/d035a752e0b59821b53bf493adf722af/decd484da16ecde458f0b9f9a52dc678.gif)
This audio filter has a 200Hz bandpass centered at 700Hz, with a tolerance of 1% for the resistors and 5% for the capacitors.
- Schematic diagram of car cigarette lighter to USB power port
- What kind of circuit is a voltage regulator circuit?
- Op amp power supply decoupling bypass measures
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Transformerless AC-DC constant current LED driver circuit
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- LED Driver ZD1680
- Miniature polarity reversal power supply using MAX1721
- A simple positive and negative power supply circuit
- 0.7~24V continuously adjustable current limiting power supply
- Teach you a reliable new method to implement overvoltage protection for electronic signal inputs
- Amid the Sino-U.S. trade war, U.S. semiconductor manufacturers begin to relocate abroad
- InnoSwitch-CE switching power supply IC related technical indicators
- A design plan for a serial communication interface circuit
- Circuit diagram of using photoelectric coupler to make mobile phone call reminder
- What’s so magical about the main circuit inside the inverter?
- Phase detection circuit
- Op amp clamp circuit
- volumeter
- Unity gain four input audio mixer
