DC adjustable voltage stabilized power supply circuit diagram composed of L296
Source: InternetPublisher:李商隐身 Keywords: Power supply circuit diagram regulated power supply circuit DC adjustable regulated power supply Updated: 2020/05/15
L296 has complete over-voltage, over-current, over-heat protection and soft-start functions. It is equipped with a reset circuit output terminal, a prohibited input terminal, a crowbar input terminal, and an output terminal. The input voltage range is wide, and the input voltage can be between 9 and 46 V as needed. Determined within; the maximum output current is 4A, the maximum output power is 160W, and the output voltage can be continuously adjusted within the range of 5.1~40V. Its package form is Multiwatt15, and the pin arrangement is shown in Figure 2.
L296 internal structure diagram
ck="window.open(this.src)" alt="Click to see larger image" />
The following is a circuit diagram of a 4A DC adjustable regulated power supply with an output of 5.1~40V. Since there is no reset output, pins 12, 13, and 14 are left floating. The overvoltage protection is not used, so pin 15 is left floating and pin 1 is grounded. You can see the circuit. Very simple and easy to make.
- Energy-saving motorcycle rectifier regulator
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Simple and practical LED lamp driving circuit
- Constant current LED lamp driver circuit with soft start and anti-shock
- Switching power supply circuit composition and function introduction of each part
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Car power 1.5V-12V six-speed converter
- The production of adjustable voltage-stabilized power supply composed of LM317
- MAX1811 Lithium Battery Charger Production
- LM317T voltage regulation adjustable circuit diagram explanation
- Portable device charging power circuit design
- Power circuit with smoothing filter capacitor
- Power supply circuit with multiple outputs (MAX1902)
- Timing switch AC power circuit
- Additional power circuit design for USB devices
- Low voltage adjustable reference power circuit
- Common power circuits and applications 08
- 5V uninterruptible power supply circuit
- ±5V, ±12V power circuit B
- CASPER TM-5158 VGA color display power supply circuit
