Additional power circuit design for USB devices
Source: InternetPublisher:刘德华河北分华 Keywords: USB power circuit circuit design Updated: 2021/10/01
Most of the USB devices used today sometimes cause lack of power issues. How do you know the maximum current that can be drawn from a single USB connector is limited to 500mA . If your device requires more current, then it must include an additional USB port, which may not be available. This problem can be solved with an additional tool that uses an external unstable power supply and converts it to 5 volts.
There are two different methods you can use. There are two different methods you can use. The first, and maybe the simplest - use a simple linear regulator, but this causes other problems - wasted consumption power, but you can go the other way and use a pulse transformer, which is much more economical.
Note: The basis of the converter is a PWM controller based on the LM 2575-5 integrated circuit with an output of 5 Volts up to 1A. Enable/disable the converter using 5-pin on/off, controlled transistor VT 1.
- Benefits of Wide Bandgap Technology for Power Converters
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Fabrication of multi-cell lithium battery charging circuit
- Energy-saving motorcycle rectifier regulator
- Step-down power supply for driving relays
- ISO113 circuit that can reduce power consumption
- Power supply circuit that can reduce LM317 ripple
- Homemade low-power UPS
- Mc34063 MP3 Switching Charger
- A low-cost, high-reliability battery charger for electric vehicles
- Design of adjustable DC stabilized power supply circuit module
- Laser power circuit
- Portable device charging power circuit design
- 3v to 5v circuit diagram
- Typical Reference Voltage and Power Supply Circuits
- High current (4A) switching regulator integrated circuit L296 outputs 5.1 to 40V
- Power supply circuit with multiple outputs (MAX1902)
- Transistor stabilized current power supply circuit 2
- Telephone power circuit
- ±5V, ±12V power circuit A
