Power frequency noise double T filter circuit
Source: InternetPublisher:刘德华河北分华 Keywords: noise filter circuit power supply Updated: 2020/07/04
The figure below shows a power frequency noise filter circuit . This circuit is a double-T filter that can be used to filter out the mixed noise of the 50Hz (or 60Hz) power supply frequency when amplifying weak signals (such as sensors, etc.). If only RC components are used to form this type of filter, its Q value is generally low and has broadband attenuation characteristics. Using an op amp and adding positive feedback can improve the Q value. Suppose the Q value at this time is Q', then Q'=Q/(1-K), in the formula, K=RA/(RA+RB). Changing the coefficient K can increase the Q value. The resonant frequency of the circuit is fo=1/2πRC, and the positive feedback components are R/2 and 2C. Considering the dispersion of the characteristics of the capacitor, the resonant frequency should generally be set lower, and then the potentiometers PR1 and PR2 are used to adjust the frequency to 50Hz (or 60Hz). When adjusting, input a 50Hz (or 60Hz) sinusoidal voltage, and adjust PR to minimize the output voltage passing through the filter. When using this filter, if the input power supply noise is not a sine wave, high-frequency components will pass through the filter. High-order harmonics in the AC power supply are generally odd-order harmonics such as 3, 5, and 7. These harmonics can be filtered out by connecting a low-pass filter.
ck="window.open(this.src)" alt="Click to see larger image" />
- Practical and convenient fax machine power supply control circuit
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- What kind of circuit is a voltage regulator circuit?
- LNK304 non-isolated LED light string driver circuit
- A small and easy-to-make fast charger
- Power supply circuit that can reduce LM317 ripple
- Homemade low-power UPS
- CNC regulated power supply production
- 0.7~24V continuously adjustable current limiting power supply
- Adjustable voltage regulated power supply circuit
- Provides USB Type-C® port chip solutions for lithium battery-powered devices
- Principle and circuit diagram of battery internal resistance tester
- White noise electronic lullaby circuit diagram
- LC filter and LC-π filter circuita
- Pulse shaping circuit using inverters
- Internal circuit principle of M65831
- Direct heating rectifier tube full-wave rectification and filter circuit
- Power frequency noise double T filter circuit
- Electromechanical control filter circuit
- Simple noise meter
