LC filter and LC-π filter circuita
Source: InternetPublisher:风向西瓜 Keywords: Filter circuit LC filter BSP LC filter Updated: 2021/12/03
Through the analysis of capacitor filter or inductor filter, the DC output still fluctuates more or less. In situations with higher requirements, in order to obtain smoother
DC, a complex filter can be used. .
(1) LC filter We know that the t-capacitor filter is suitable for situations where the load is large, while the inductor filter is suitable for situations where the load is small.
If these two circuits are combined, they will form the circuit shown in Figure 12-16a. The filter shown is suitable for general loads.
In LC filter. The pulsating voltage will go through double filtering, so that most of the AC component is blocked by the inductor L. Even if a small part
passes through L, the AC will be bypassed by the filtering effect of the capacitor C. Therefore, the AC component on the load is very small. , thus achieving
the purpose of filtering out communication.
(2) The LC-type filter circuit is shown in Figure b. IJC-type filter is a combination of C-type filter and LC filter
. The
filtering process is that after the alternating current is rectified, it is first filtered by the C-type filter, and then filtered by the LC filter . Therefore, the performance of type-type filters
is superior to that of LC and C-type filters, and the voltage obtained on Rr. will be smoother.
Since there is a capacitor connected in front of the LC-7C filter, the external characteristics of this filter are similar to those of the capacitor filter.
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Using Lead-acid Battery as Power Source for Walkman
- Use pulse width modulation to get a precise output voltage
- The constant current source composed of two transistors can drive high power
- Detailed explanation of 5v charger circuit diagram
- Miniature polarity reversal power supply using MAX1721
- A simple positive and negative power supply circuit
- Homemade low-power UPS
- 3~15V 10A adjustable voltage regulated power supply
- Production of backup power supply for cordless phone
- electromagnetic field sensor
- Ultrasonic blind pathfinder circuit
- Electronic anti-asthma circuit
- Crop anti-frost circuit
- Frequency modulator composed of NE566
- Varactor Diode Frequency Modulator
- Amplitude modulation circuit composed of MC1496
- Crabo oscillator circuit
- Power phase sequence display circuit
- Various signal generator circuits
