Low voltage DC power charger circuit diagram
Source: InternetPublisher:同住地球村 Keywords: Low voltage charger circuit diagram power charging DC power supply Updated: 2020/01/11
This circuit can be used to charge cadmium-nickel batteries and dry batteries after high current use, and can also be used as a general low-voltage DC power supply .
This circuit consists of a charging part and a DC output part. K2 is the fast charge and slow charge selection switch, R2 and R3 are current limiting resistors, which can change the charging current. Usually, fast charging is controlled at about 4 hours, and slow charging is about 14 hours. NA, ZD form the test circuit. Before charging, install the battery to be charged. When you press AN, it is normal for the ZD to have no light or a faint light. When the charging time reaches the requirement, after pressing AN, if the ZD glows for more than 10 seconds, it means that the charge is full and can be used with electrical appliances.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- LED rechargeable flashlight circuit diagram
- Principles and precautions of active discharge circuit
- Low cost and high performance LED constant current power supply
- Miniature polarity reversal power supply using MAX1721
- Constant current charger using light emitting diode as voltage regulator
- UC3842 Electric Vehicle Charger
- Circuit diagram explanation: simple switching power supply circuit diagram
- Homemade home inverter circuit diagram
- Car battery charger circuit diagram
- Ignite fluorescent lamp circuit at low temperature and low pressure
- Capacitor low voltage centralized compensation circuit
- Simple quick charger
- DC low voltage fuse blown indication circuit
- Low dropout 5V voltage regulator circuit
- Low Cost Low Dropout Linear Regulator Circuit
- Low voltage breaker circuit diagram
- low voltage flasher
- Safety low voltage transformer circuit diagram
