Lithium battery fast charger circuit diagram
Source: InternetPublisher:拿铁三分糖 Keywords: Charger circuit diagram fast charger lithium battery Updated: 2020/02/23
This circuit has a charging status display function. The red light flashes and is charging, the green light flashes and is about to be fully charged. The green light illuminates and is fully charged. As long as you have a 12V power supply, don't install the battery after connecting the circuit. Adjust the adjustable resistor in the lower right corner so that the battery output is 4.2V. Then adjust the adjustable resistor in the lower left corner so that the third pin of LM358 is 0.16V. That's it. The charging current is 380mA, which is super fast. The three parallel-connected diodes are step-down to prevent the LM317 from overheating, and a heat sink must be added to the LM317. The triode in the picture can be of any type.
ck="window.open(this.src)" alt="Click to see larger image" />
- 220V Remote Load Monitor
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- LED Driver ZD1680
- Dynamic power supply for power amplifier controlled by thyristor
- A small and easy-to-make fast charger
- Design of electric vehicle charger
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- MAX1811 Lithium Battery Charger Production
- Detailed explanation of mobile phone charger circuit diagram
- 5V-USB charger circuit diagram
- Low voltage DC power charger circuit diagram
- Lead acid battery charger circuit diagram
- Car battery charger circuit diagram
- Nickel-cadmium battery fast charger circuit diagram
- Simple nickel-cadmium battery charger circuit diagram
- Charger circuit diagram that automatically stops charging
- No temperature sensor, DC power supply linear charger circuit diagram
- Charger circuit diagram with repeated charging function
- Multipurpose constant current automatic charger circuit diagram
