A classic 35W power amplifier circuit diagram
Source: InternetPublisher:拿铁三分糖 Keywords: tube amplifier Updated: 2024/01/05
This is the circuit diagram of EL34 for 35W tube amplifier. This tube amplifier was designed in 1953 and was in operation from 1954 to 1989. If you are interested in classic circuits and classic components, you should try this circuit. The circuit is interesting, but I think the tubes will be hard to find.
Schematic diagram, schematic diagram:
power supply:
Component list:
This is a classic 35W power amplifier design using tubes, two EL34 connected Push-Pull, designed by Siemens & Halske, design date 03/24/1953, code SV410/1. The amplifier was in operation from 1954 to 1989, whenever it was and disappeared, with an average lifespan of 15 hours per day. Other than the replaced tubes, resistors and capacitors, it shows no particular damage due to natural wear and tear.
One notable change was the replacement of the rectifiers for the lamp diodes. The only problem for those trying to build, will be the output transformer (for all tube manufacturers), as the code doesn't help. Can be replaced with a conventional output transformer suitable for EL34. During construction, sufficient electronic experience and attention to high voltage, risk of electric shock are required (respectively for all circuits).
- Analysis of the flow direction of transistor current
- Signal diode arrays/configurations, freewheeling diode operation
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- FPGA Features and Architecture
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- RC filter explained in detail
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- Make a flameless electronic candle using simple electronics and LEDs
- What is the difference between JFET and MOSFET
- Simple LED advertising light circuit
- Tube power amplifier driven by NE553202
- Tube power amplifier driven by NE553201
- Debugging of tube amplifier 02
- Debugging of tube amplifier 01
- 8W pure class A tube power amplifier circuit
- 555 square wave oscillation circuit
- 555 photo exposure timer circuit diagram
- Introducing the CD4013 washing machine timer circuit diagram
- Simple level conversion circuit diagram
- 555 electronic guide speaker circuit diagram for blind people
