LED emergency light circuit diagram powered by ordinary AAA batteries
Source: InternetPublisher:笑流年 Keywords: LED emergency light battery powered circuit diagram Updated: 2021/02/14
This LED lamp circuit uses high-brightness white LED with a reflector. The lamp pole is made of a metal spiral tube, which can be bent and turned to adjust the angle of the lamp head. The lamp holder is equipped with a push-button switch. It is compact, practical and easy to carry. Figure 1 is its circuit diagram .
When the battery voltage is 4.38V, the operating current is measured to be about 150mA, and the voltage drop on the LED is 3.2V. In order to effectively extend the battery life, the author decided to connect a small value current-limiting resistor in series behind the button switch K. After repeated tests, when using a 2.7Ω resistor, the current dropped to 120mA, and the brightness did not change significantly. If you think the battery is expensive, you can also use 220V AC mains power. This requires a suitable power adapter. It is recommended to use a discarded mobile phone battery charger at home. Since mobile phone charger plugs come in many different shapes, you need to use a mono in advance. After modifying the headphone plug, the charger I found has an output voltage of 6.28V. The circuit schematic diagram after the modification is shown in Figure 2, and the measured operating current is about 138mA.
- LED acceleration and deceleration motion display composed of CD4017
- DIY a hat with a programmable LED display
- IRS2530D electronic ballast circuit diagram
- Use NE555 to make a lighting and sound changing circuit
- Low illumination amplifier circuit
- SC3071 touch step dimming light circuit
- Digital display multi-function thermometer circuit
- Incandescent lamp dimming circuit using thyristor part 4a
- Mains undervoltage and overvoltage alarm circuit 2
- Bedside lamp controller circuit
- MAX684 charge pump driving white LED circuit diagram
- MAX8630Y/ MAX8630Z driving white LED circuit diagram
- SG1524 driver LED circuit
- LT3755 driver LED application circuit diagram
- Driving circuit diagram of a low-power LED bulb
- LED signal amplification circuit diagram
- LED level meter driver integrated circuit diagram
- Transformer overtemperature alarm circuit
- 4 and 1/2 LED digital display (DMS-40PC series)
