Sound-activated infrared remote control switch circuit diagram
Source: InternetPublisher:柯南道尔 Keywords: Voice control switch circuit diagram infrared remote control switch Updated: 2020/08/26
The infrared remote control switch generator circuit using the sound control circuit BH-SK-I is shown in the figure below. The generator is a multivibrator composed of 555. The generated pulse drives the infrared pulse signal through the external emitting diode. The receiving tube is paired with the transmitting tube, which turns the infrared light pulse into an electrical signal, which is pre-amplified by BG1 and triggers the IC 2 voice-activated integrated circuit BH-SK-I. After being triggered, its 12-pin outputs a high level, causing the BG2 conduction relay to close the socket CZ and get electricity. If it is shut down, you only need to press the button AN of the generator . The internal trigger of IC 2 will flip, output low level, BG2 will be cut off, the relay will be released, and the socket will lose power.
- Why does CAN FD communication need to enable TDC for sending and receiving delay compensation? How to configure TDC and SSP in TCAN4550?
- Types/advantages and disadvantages of repeaters, how do repeaters work?
- Application of GaN power devices in array radar transceiver systems
- Design and production of satellite receiver crash recovery circuit
- Wireless transmission of integrated TV signals for amateur productions
- FMA9901A FM broadcast dedicated antenna
- Homemade FM wireless microphone for teaching
- U3742BM ASK/FSK 433.92/315 MHz Receiver
- RCV420 4~20mA Precision Current Loop Receiver
- Stereo FM transmitter circuit designed with BH1417
- Voice controlled toy car circuit
- Voice control signal acquisition circuit diagram
- Circuit diagram of using SK-IV's voice-activated automatic lighting to accompany music
- Practical voice-controlled music lantern (2)
- Sound controlled photosensitive delay switch circuit
- Voice controlled running water music lantern circuit
- Voice controlled toy electronic dog circuit
- Sound-activated bistable electronic switch circuit
- Piezoelectric crystal voice controlled light
