Light controlled ringing circuit diagram
Source: InternetPublisher:无人共我 Keywords: Light control ringing circuit diagram Updated: 2021/05/18
Ordinary telephone ringing circuits are mostly composed of KA2401 and peripheral components. When installing a light- controlled bell, you only need to connect the light-controlled circuit shown in country (b) at the "X" in country (a): the external line has When the AC ringing signal is input, pin 8 of KA2401 outputs a two-tone ringing signal. If it is daytime, the resistance of the photosensitive tube 3DU is small, the thyristor SCR is turned on, and the ringing sound is loud; if there is no light at night, the resistance of 3DU is very ( Several megohms), the ringing signal can only pass through R2 after being attenuated, and the ringing sound will be much smaller.
ck="window.open(this.src)" alt="Click to see larger image" />
- Methods to reduce mutual coupling between antenna elements
- TA8164P FM Radio
- Using 3DA87C to make FM transmitter circuit
- Wireless doorbell production
- RF2948B QPSK 2.4 GHz Spread Spectrum Transceiver
- RF2919 ASK/OOK 915/868/433 MHz Receiver
- Rolling code radio transmitter circuit (HSC360/TDA5100)
- nRF903 GMSK/GFSK 950~430 MHz transceiver
- RF2516 AM/ASK/OOK 433/315 MHz Transmitter
- rfHCS362G/362F ASK/FSK 440~310 MHz KEELOQ Code Hopping Transmitter
- Light controlled motor drive circuit
- Five-speed fan speed control circuit with light control
- Discrete component sound and light control stair delay switch circuit (5)
- Use PSSR to make light-controlled automatic street lights
- PT2102 dimming control ASIC
- HT7713 dimming control ASIC
- BA5173, HT7706 dimming control application specific integrated circuit
- BA2101, SM9403 dimming control application specific integrated circuit
- Light controlled bird circuit 02
- Light controlled delayed flash toy car circuit
