Time controller circuit diagram made by CD4060
Source: InternetPublisher:睡不醒的小壮 Keywords: Controller circuit diagram time controller CD4060 Updated: 2020/01/18
Use CD 4060 to make a time controller as shown in the figure below. The moment the circuit is turned on, the differential circuit composed of R5 and C3 ensures that the delay time starts from zero. Under the action of the oscillation signal, the counter in the CD4060 starts to work. Pin 3 is the output end of the 14th level counter. To convert pin 3 from low level to high level, the time required is t=213×2.2KC (seconds), during this period, the low voltage output by pin 3 causes the transistor V to cut off. When the delay time comes, pin 3 jumps from low level to high level, and V is saturated and turned on through R6 current limiting, relay K is closed, and the load is powered. The delay time of this circuit can be adjusted arbitrarily within 2.1~4 hours.
- How to choose the right level of integration to meet motor design requirements?
- Design of an autonomous plant watering system using ATtiny85
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- A simple door handle touch alarm circuit
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Design and analysis of the principle of automatic power-off switch during power outage
- PIC microcontroller controlled remote anti-theft alarm circuit
- Homemade short circuit alarm device
- Bicycle anti-theft alarm
- Pyroelectric automatic door control circuit
- Photoelectric tracking control circuit
- NE555 school bell automatic controller circuit diagram
- Infrared automatic faucet controller circuit diagram
- Circuit diagram of automatic water level controller for two new applications
- Eight-level touch volume controller circuit diagram composed of 74L194
- Fluid Level Controller Circuit Diagram
- Monolithic electric pump controller circuit diagram
- Sequential timing controller circuit diagram
- Telephone automatic recording controller circuit diagram
