Integrated circuit adjustable thermostat circuit diagram
Source: InternetPublisher:zht24 Keywords: Thermostat circuit circuit diagram integrated circuit WIDTH Updated: 2020/09/12
As shown in the figure, the TC620 with built-in temperature sensor controls the triac to achieve temperature control. Adjusting Rp1 and Rn in the circuit can change the lower limit temperature control point and the upper limit temperature control point respectively. LED1 lights up to indicate that the ambient temperature exceeds the lower limit temperature control point, and LED2 lights up to indicate that the ambient temperature exceeds the upper limit temperature control point. The selection of the rated operating current of the triac BCR can be determined based on the actual controlled load power.
ck="window.open(this.src)" alt="Click to see larger image"/>
- Design and selection of electric control valve system drive
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- DIY an electromagnetic levitation device
- What are the challenges in designing a permanent magnet linear generator?
- Introduction to the internal structure of the Delta winding motor
- How to set up a cheap beam break sensor control distance scene using a reflector
- Design and analysis of voice control circuit
- Electric vehicle battery charging protection circuit
- Infrared detection alarm
- Night dog barking anti-theft reminder circuit
- LA4555 power amplifier circuit diagram
- LA4500 power amplifier circuit diagram
- LA4480 power amplifier circuit diagram
- LA4261 power amplifier circuit diagram
- Ringing switch start protection circuit diagram
- Nickel cadmium charger circuit diagram
- Video switching circuit diagram
- MAX9489 charging circuit diagram
- Spike peak measurement circuit diagram
- MC4024P simply constructs a signal generator circuit diagram
