Simplified electronic ballast circuit diagram
Source: InternetPublisher:方世玉223 Keywords: Electronic ballast circuit diagram WIDTH Updated: 2021/05/19
In a building, when the full-power continuous operation of fluorescent lamps is not required, the application of dimmable electronic ballasts can further reduce the power consumption in the building and achieve energy saving. Most modern electronic ballast designs and studies recommend the use of resonant converters as power circuits for driving lamps . Figure 1 shows a simplified ballast circuit. The two switches S: and S2 alternately switch in turn to provide a high-frequency (usually within 25 kHz and 100 kHz) rectangular wave AC voltage , which is applied to the loaded resonant circuit. Blocking (breaking) DC (current) capacitors are used to eliminate DC voltage components. The basic concept is to utilize the resonant voltage applied to the resonant capacitor C, in order to initiate the impact of the lamp arc. Because of the high frequency of the excitation voltage, the lamp is actually in a continuous conduction state, so it can provide high-quality lighting without flicker effects.
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- A very convenient small power supply circuit to share
- How to Make a Soft Latch Circuit
- Practical and convenient fax machine power supply control circuit
- Use pulse width modulation to get a precise output voltage
- Driving circuit that controls LED brightness using PWM signal
- Constant current LED lamp driver circuit with soft start and anti-shock
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Integrated regulated power supply with continuously adjustable output voltage
- Homemade home inverter circuit diagram
- AN7161N power amplifier circuit diagram
- Subwoofer crossover amplifier circuit diagram
- MJE13005×2 electronic ballast circuit diagram
- 5V-USB charger circuit diagram
- MAX1870A - Typical Operating Circuit
- Field output circuit: TDA8351AQ circuit diagram
- Electric fan induction braking circuit diagram
- Automatic telephone call recording circuit
- Simple signal generator for signal tracing
- Controllable voltage variable gain amplifier
