AC and DC inflow automatic switching circuit diagram
Source: InternetPublisher:念慈菴 Keywords: AC and DC switching circuit circuit diagram automatic switching Updated: 2021/02/09
The figure below shows the AC/DC inflow automatic switching circuit . After the mains voltage is stepped down by transformer T1, it is then rectified, filtered, and stabilized before being output for load operation. At the same time, another DC voltage generated through rectification and filtering is divided by RP and added to the base of VT2. VT2 is turned on and VT1 is turned off. When the mains power is interrupted, VT2 changes from on to off. At this time, the power field effect transistor VT1 is on, and the battery is added to the voltage stabilizing circuit through VT1 to output a stable DC voltage for negative interception. Due to the use of MOSFET for fast electronic switching, this circuit achieves the purpose of uninterrupted power supply.
- Analysis of the working principle of switching regulator
- How to Make a Soft Latch Circuit
- Benefits of Wide Bandgap Technology for Power Converters
- Visible laser digital control modulation driver
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Switching power supply circuit composition and function introduction of each part
- Charging control circuit made by solar energy
- A novel and practical DC low voltage stabilized power supply
- 3~15V 10A adjustable voltage regulated power supply
- Electric bicycle battery charger circuit
- Excellent performance household inverter power supply circuit
- Solar power circuit
- High current (4A) switching regulator integrated circuit L296 outputs 5.1 to 40V
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- Modified AC and DC dual-purpose arc welding machine circuit
- One of the transistor stabilized current power supply circuits
- M9700 digital multimeter circuit
- AC-DC conversion power supply-AC-DC switching circuit
- AC and DC inflow automatic switching circuit diagram
- Video signal switching circuit
