Solar power circuit
Source: InternetPublisher:蓝猫淘气 Keywords: Power circuit solar power supply BSP silicon photovoltaic cell Updated: 2021/05/09
Solar energy is an inexhaustible source of energy. Solar radios do not use dry batteries as a power source, but use solar energy as an energy source.
The components that convert light energy into electrical energy are several thin solar cells. The schematic diagram of
the solar power supply is shown in the figure. Before introducing the circuit principle, let's briefly talk about the characteristics of silicon photovoltaic cells (ie, solar cells)
. Silicon photovoltaic cell is a physical battery that can directly convert light energy
into electrical energy. It has
the characteristics of small size, light weight, easy to use and store, and small reaction to temperature changes.
And its service life is almost permanent, usually at least
ten or twenty years. Its size comes in a variety of specifications, and the commonly
used ones are 10mm×20mm, 20mmx20mm,
etc. Its blue-black side is called the light-receiving surface. Only when light shines on
the light-receiving surface, the silicon photovoltaic cell will generate voltage.
There are several silver grid lines on the light-receiving hoop , and the two
wires drawn from the grid lines are the electrodes (upper electrodes) of the light-receiving surface. The opposite side that receives light - the backlit side is silvery white.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Recommended circuits for different power on times of LM4911
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Detailed explanation of 5v charger circuit diagram
- Parallel DC regulated power supply circuit diagram
- LNK304 non-isolated LED light string driver circuit
- Power supply circuit that can reduce LM317 ripple
- MIC4680 constant current charger
- Homemade home inverter circuit diagram
- Set timing circuit when power is on
- electromagnetic field sensor
- Double detuned loop frequency discriminator circuit
- Simple AGC circuit in transistor radio
- Diode square rate detection circuit
- Audio function generator composed of ICL8038
- Wien bridge oscillator circuit
- Differential Amplifier Circuit
- High and low frequency signal generator circuit
- Digital stopwatch display circuit
