Analysis of internal reset circuit diagram of microcontroller
Source: InternetPublisher:fish001 Keywords: Microcontroller power supply and other power circuits Updated: 2021/09/26
The principle of the reset circuit is to connect an external resistor and capacitor to the reset pin RST of the microcontroller to achieve power-on reset. Reset is valid when the reset level lasts for more than two machine cycles. The duration of the reset level must be greater than two machine cycles of the microcontroller. The specific value can be calculated from the time constant by the RC circuit.
As shown in the figure below, the microcontroller reset circuit is composed of two parts: key reset and power-on reset. Among them, the STC89 series microcontroller has a high-level reset. Usually, a capacitor is connected to the reset pin RST to VCC, and then a resistor is connected to GND. This forms an RC charge and discharge circuit to ensure that the microcontroller is on the RST pin when it is powered on. There is enough time for the high level to reset, and then returns to the low level to enter the normal working state. The typical values of this resistor and capacitor are 10K and 10uF. The button reset is to connect a switch in parallel with the reset capacitor. When the switch is pressed The capacitor is discharged, RST is also pulled to a high level, and due to the charging of the capacitor, it will remain high for a period of time to reset the microcontroller.
- Single-power supply circuit for ISO122P/ISO124
- Op amp power supply decoupling bypass measures
- The constant current source composed of two transistors can drive high power
- LED Driver ZD1680
- Detailed explanation of 5v charger circuit diagram
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Car Audio Power Supply
- MAX1811 Lithium Battery Charger Production
- LM317T voltage regulation adjustable circuit diagram explanation
- Detailed explanation of mobile phone charger circuit diagram
- Design of temperature detection circuit implemented by single chip microcomputer
- Teach you a reliable new method to implement overvoltage protection for electronic signal inputs
- Vishay FRED Pt® ultra-fast recovery rectifier launched on the market
- Utilizing light sensing circuits to reduce photodiode bandwidth and noise effects
- About star-delta step-down start plc ladder diagram circuit diagram
- About the working principle of single touch mode light switch
- Minimum system interface circuit based on AT89C52 microcontroller
- Microcontroller measurement circuit
- IR2130 combined with microcontroller and SLE4520 for three-phase frequency conversion system diagram
- Interface between serial IO port AD converter and microcontroller
