Vishay FRED Pt® ultra-fast recovery rectifier launched on the market
Source: InternetPublisher:qoistoochee128 Keywords: Vishay rectifier power supply and other power circuits Updated: 2020/10/20
New 200 V Fred Pt® ultra-fast recovery rectifiers, including the industry's first 2 A rated device - 1 A VS-1EQH02HM3 and 2 A VS-2EQH02HM3. 1 A VS-1EQH02HM3 and 2 A VS-2EQH02HM3 rectifier outlines With dimensions of 2.5 mm x 1.3 mm and a height of only 0.65 mm, it can replace SMA packaged rectifiers to save space. In addition, there are commercial versions 1 A VS-1EQH02-M3 and 2 A VS-2EQH02-M3.
The device released recently adopts a smaller MicroSMP package, with a typical rated current equivalent to that of an SMA package, has higher power density, and saves 57% of PCB space. VS-1EQH02HM3 and VS-2EQH02HM3 adopt an asymmetric design. The large-area metal gasket is conducive to heat dissipation, and the thermal performance is extremely excellent. FRED Pt technology achieves an ultra-fast recovery time of 13ns, and Qrr is reduced to 11nC, at -55 °C to +175 °C. C has soft recovery function over the entire operating temperature range.
The rectifier has passed AEC-Q101 certification, and the forward voltage drops to 0.72 V under 1 A condition, which effectively reduces power consumption and improves efficiency. It is suitable for automotive engine control units (ECU), anti-lock braking systems (ABS), HID and LED lighting. , high-frequency inverters, DC/DC converters, freewheeling diodes, and power factor correction circuits in communication and industrial power supplies.
The moisture sensitivity level of VS-1EQH02HM3 and VS-2EQH02HM3 reaches J-STD-020 standard level 1, and the highest LF peak is +260°C. The device complies with RoHS standards, is halogen-free, and is suitable for automatic patch processing and automatic optical inspection (AOI) of automotive systems.
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Build a simple buck-boost regulator and test it on a breadboard
- Schematic diagram of car cigarette lighter to USB power port
- Benefits of Wide Bandgap Technology for Power Converters
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Dual forward converter schematic diagram
- A small and easy-to-make fast charger
- Electric bicycle battery charger circuit
- Car Audio Power Supply
- The German government confirms that Huawei will not be excluded from 5G network construction
- Car sales fell in September, followed by new energy vehicles
- Diode selection plays a vital role in circuit design
- SKiiPPACK unit circuit
- Two-channel low-power amplifier circuit
- Differential bridge amplifier circuit diagram
- An operational amplifier with very high amplification
- IC4069 simple infrared remote control switch circuit diagram
- phono preamplifier
- Music doorbell circuit with two triggering methods
