bass boost circuit
Source: InternetPublisher:newrudeman Keywords: Power supply other power supply circuits operational amplifiers Updated: 2021/06/20
The speaker's poor bass response is compensated for using an external series RC circuit between pins 1 and 5 and the op amp's internal 151K resistor in parallel. If the resistor is 15K, and the minimum value for stable operation is 10K, you can get 6 decibels of effective bass enhancement.
- How about the boost converter TPS61299?
- Parallel DC regulated power supply circuit diagram
- How to use SBR to improve power conversion efficiency
- LNK304 non-isolated LED light string driver circuit
- Charging control circuit made by solar energy
- A simple positive and negative power supply circuit
- Homemade low-power UPS
- Car Audio Power Supply
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Practical constant current charger-----Constant current charger
- Take stock of wonderful designs
- A brief discussion on the circuit diagram of electrical control
- About the internal 5G28 circuit diagram of the integrated operational amplifier
- Two-channel low-power amplifier circuit
- VEMD6010X01 reference design circuit | PIN photodiode application circuit
- Heart rate detection circuit
- op amp mixer
- How to use "virtual short" and "virtual break" to analyze op amp circuits
- simple audio mixer
- audio oscillator
