Wiring method of three-phase four-wire external transformer energy meter
Source: InternetPublisher:黄土马家 Keywords: Three-phase four-wire power electrical circuit energy meter external transformer Updated: 2021/10/26
Turn over the terminal cover and you can see the three-phase four-wire meter wiring diagram. Among them, 1, 4, and 7 are connected to the S1 terminal of the secondary side of the current transformer, which is the current incoming terminal; 3, 6, and 9 are connected to the S2 terminal of the secondary side of the current transformer, which is the current outgoing terminal; 2, 5, and 8 are connected to the three terminals respectively. Phase power supply; 10 and 11 are connected to the zero terminal. For safety reasons, the S2 terminal of the current transformer should be connected to ground. Note that the current measurement sampling of each current transformer must be in the same phase as its voltage sampling, that is, 1, 2, and 3 are a group; 4, 5, and 6 are a group; and 7, 8, and 9 are a group.
Three-phase four-wire electric meter wiring diagram without current transformer
Three-phase four-wire electric meter wiring diagram with current transformer
Wiring diagram of three-phase four-wire electricity meter with transformer
- 5 Converter Topologies for Integrated Solar and Storage Systems
- In-depth analysis of DC-AC converter inverter
- 220V Remote Load Monitor
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Recommended circuits for different power on times of LM4911
- Simple and practical LED lamp driving circuit
- LNK304 non-isolated LED light string driver circuit
- An ultra-low output voltage regulator
- Converting a lithium battery charging board into a constant voltage and current charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- STR5412 power circuit
- 24V power supply pure flat display high voltage power supply circuit diagram
- Voltage stabilization control circuit in power circuit
- Commonly used power circuits in printers
- Three-phase four-wire TN-S bus connected dual power conversion circuit
- Use three single-phase power meters to measure the power connection of a three-phase four-wire circuit
- The three-phase four-wire active energy meter is connected to the circuit through two current transformers.
- Timing switch AC power circuit
- audio power circuit
- Common power circuits and applications 06
