Mobile phone universal charger circuit diagram and working principle
Source: InternetPublisher:小胖友 Keywords: Battery power supply universal charger circuit diagram Updated: 2021/06/05
Working principle: The circuit is mainly composed of an oscillation circuit, a charging circuit, a voltage stabilizing protection circuit, etc. Its input voltage is AC220V, 50/60Hz, 40mA, the output voltage is DC4.2V, and the output current is 150mA~180mA. Before charging, first connect the battery to be charged and see if the test indicator light on the charger panel is on. If it is on, it means the polarity is correct and you can turn on the power supply for charging; otherwise, it means the polarity of the battery and the output voltage of the charger are different. The polarity is reversed. At this time, you need to press the polarity conversion switch AN1 (test button).
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Step-down power supply for driving relays
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Constant current LED lamp driver circuit with soft start and anti-shock
- Car Audio Power Supply
- A low-cost, high-reliability battery charger for electric vehicles
- Homemade Electric Bike Fast Charger
- Circuit diagram explanation: simple switching power supply circuit diagram
- Use TL431 to make a simple charger circuit
- Battery Monitor for Constant Boost Converter
- Large range 7~40V to 5VDC-DC step-down circuit diagram
- DC 12V to AC 100V inverter power supply circuit design
- KGDS type single-phase low temperature iron plated power supply circuit
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- One of the transistor stabilized current power supply circuits
- Household emergency power circuit 02
- Neon light high voltage power supply circuit
