9012, 9013 OTL discrete component power amplifier circuit diagram
Source: InternetPublisher:smallembedded Keywords: Power supply other power circuits Updated: 2021/04/22
![9012, 9013 OTL discrete component power amplifier circuit diagram](http://www.eeworld.com.cn/circuit/upload/84b4baaa4dcb3120e691d3d3e86a23a6/071369ac4c88e0121aa3e015a2b6c485.jpg)
Q1 is the excitation amplifier tube, which provides sufficient push signal to the power amplifier output stage; R1 and RP2 are the bias resistors of Q1; R3, D1, and RP3 are connected in series on the Q1 collector circuit to provide bias for Q3 and make it static is in a micro-conduction state to eliminate crossover distortion; C3 is a damping capacitor, used to eliminate possible self-excitation in the circuit; Q2 and Q3 are complementary symmetrical push-pull power amplifier tubes, forming a power amplifier output stage; C2, R4 Form a "bootstrap circuit", R4 is the current limiting resistor.
Circuit debugging
Connect the 3-6V DC power supply, adjust RP2 so that the midpoint voltage of Q2 and Q3 is 1/2 the power supply voltage; adjust RP3 so that the quiescent current of the power amplifier output stage is 5-8mA; repeatedly adjust RP2 and RP3 to make the two parameters equal. reach the above value.
- Sharing layout and tips for multi-rail power supply design
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- 5 Converter Topologies for Integrated Solar and Storage Systems
- How to Make a Soft Latch Circuit
- Schematic diagram of car cigarette lighter to USB power port
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Transformerless AC-DC constant current LED driver circuit
- A simple positive and negative power supply circuit
- MIC4680 constant current charger
- A low-cost, high-reliability battery charger for electric vehicles
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
