Pressure signal conditioning circuit circuit diagram based on MAX1450
Source: InternetPublisher:aerobotics Keywords: Analog signals power supplies and other power circuits Updated: 2021/08/24
![175610797.JPG](http://www.eeworld.com.cn/circuit/upload/3e97f395f378e462b7cc259e441d7eca/e082b9fb68aa3a08199697543d040b5a.jpg)
Signal conditioning: It is a signal processing circuit that converts analog signals into digital signals for data collection, control processes, calculation display readout, or other purposes. Analog sensors can measure many physical quantities, such as temperature, pressure, light intensity, etc... However, since the sensor signal cannot be directly converted into digital data, this is because the sensor output is a rather small voltage, current or resistance change. Therefore, when converted into The digital signal must be conditioned beforehand. Conditioning is the process of amplifying, buffering, or scaling analog signals to make them suitable for the input of an analog-to-digital converter (ADC). Then, the ADC digitizes the analog signal and sends the digital signal to the MCU or other digital device for system data processing.
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- In-depth analysis of DC-AC converter inverter
- 220V Remote Load Monitor
- Basic connection circuit of signal and power supply composed of ISOll3
- Miniature polarity reversal power supply using MAX1721
- Dual forward converter schematic diagram
- LM317 regulated power supply
- UC3842 Electric Vehicle Charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- LM317T voltage regulation adjustable circuit diagram explanation
- Amid the Sino-U.S. trade war, U.S. semiconductor manufacturers begin to relocate abroad
- Utilizing light sensing circuits to reduce photodiode bandwidth and noise effects
- Circuit diagram of using photoelectric coupler to make mobile phone call reminder
- Analysis of mobile phone charger power conversion circuit
- EMC design component selection and circuit design are critical
- Valuables detection circuit design
- ×100L161 operational amplifier
- 90V/10A high power amplifier
- volumeter
- Analog signal processing circuit for speed measurement system
